2016-07-19, 18:01
(This post was last modified: 2016-07-19, 18:09 by Jorgeminator.)
As promised, here are some pictures of my station running in its final location:
![[Image: 1mFA9ny.jpg]](http://i.imgur.com/1mFA9ny.jpg)
Controller and the LTE/3G router providing the controller with an Internet connection. Voltage regulator PCB 21 is also installed.
![[Image: UoG6tEL.jpg]](http://i.imgur.com/UoG6tEL.jpg)
Shielded ferrite antennas (200mm). The pre-amp is inside the box to protect it from dust and water that might seep through the roof, just as a precaution. It's located in a very old shed with no isolation whatsoever.
![[Image: bOWUwjr.jpg]](http://i.imgur.com/bOWUwjr.jpg)
E-field probe and pre-amp. I found the performance to be satisfactory even inside, so I left it there. The noise levels are really good with no electrical equipment nearby, other than the LTE/3G router.
![[Image: kTbsuQx.jpg]](http://i.imgur.com/kTbsuQx.jpg)
Overview picture. Sorry for the mess. I kept saying to myself: "nobody sees, nobody knows".
Here you can see how thin the walls are. The ground cable (grey) goes outside the shed to an 80cm rod which I drove into the ground.
Stations: 1481
