Low Pass Filter problems
I have bought 3 off digital filter ICs but have one problem and a question.
E-Field Problem
When I select the LP filter on the E-field I just see loads of 50Hz noise.  Clearly there is an open circuit on the LP filter output, but I have been all round the chip and all connections are okay.  I am thinking it is further on in the circuit.
Has anyone had this problem and could suggest where the open circuit might be? Alternatively I can trace the signal if I had a circuit and layout diagram.  I am an electronics engineer and have access to a full workshop with lots of test kit.
H-field question
I installed LP filters on H1 and H2, they are working great and set to 16kHz, they cut my noise from 60mV to 16mV.  However, I expected the thresholds to reduce, but they haven't, so whilst I have really low noise, I actually detect less signals as the signal peaks have been smoothed a little and now don't make the thresholds.
I am running in auto mode, should I be in manual and are there any suggested settings?
Thanks
Robin
  Vin too low mt007 3 30,787 2016-12-04, 12:40
Last Post: allsorts
  Low gain on this system (Waregem) Noodweer Benelux 9 66,049 2015-07-18, 03:09
Last Post: JamesPatterson
  New station, very low stroke number Gianfran 2 26,087 2014-12-27, 09:47
  Low effectivity Snicker 13 97,431 2014-07-30, 21:24
Last Post: W3DRM
