Threads: 5
When I search, I do not see the lightning strikes on the map.
Still, the search works since the result indicates 228 impacts.
Look at the Screenshot below.
How to solve this problem?
Alexandre.
Threads: 63
(2018-08-07, 11:31)meteovergne Wrote: Hi,
Alexandre.
It's a Google interface problem... GOOGLE has priced themselves out of our market... we have been unable to update all the website scripts using alternative mapping and data processing... it is very time consuming, a very large revision, and there is a major set of upgrades in work... pleas be patient with us, but ...
continue to inform us as you notice a 'bug' or issue!
Cheers! and don't lose hope... it may be some time...
Threads: 78
The feature is working again. We still can provide the Google Map here for a month here, as the access rate is low. But it will be moved to the main map sooner or later.
