Latest Schematics
Hi Everyone,
New member, here, putting together a station on the West Coast of Scotland. As a relief from winding ferrite rods with Litz wire, I tried to look up a few signal paths on the schematics.
Although the documentation says it was updated less than 5 minutes ago, the link to the schematic diagrams only goes as far as pcb 19.4, and my board says it is version 19.5
Is there any difference? Have I missed an obvious link?
Also, is there a drawing of the front and back panels in any other format than T3000? Or, is there a file-converter that will transform them into something I can print?
Best Wishes
David
Should be just minor changes. I believe 19.4 would have the old GlobalTop GPS module and 19.5 would have the newer ublox GPS module.
(2019-05-05, 14:46)Tinny Wrote: Hi Everyone,
Best Wishes
David
Hi. For this board (19.5) there are files for box 3D printing. https://www.thingiverse.com/thing:3364124
Volodymyr
Lightning Volodymyr Lightning
Berezhany, UA
Station: 2224
Ukrainian translation for MyBlitzortung updated
(2019-05-06, 04:05)kevinmcc Wrote: Should be just minor changes. I believe 19.4 would have the old GlobalTop GPS module and 19.5 would have the newer ublox GPS module.
Thanks for the reassurances. I'll go back to the coil-winding, then.
Best Wishes
David
Volodymyr
Ukraine, Berezhany
Station: 2224
Thanks for the link, Volodymyr. That looks really good. I _must_ get myself a 3D printer, soon.
Best Wishes
D
Only nuance is that in the original the case is metallic and has a ground plane  it has ground ground so that I have the antenna of ferrite rob in inside in  room(indoor) and the Electric field in the inside in attic I decided to use the case of plastic.
In ideal it is a casing of metal and ground connections.
Lightning
Installing the Electric field on a hill(outdoor) can have bad consequences, without grounding of metal parts, is a direct hit by lightning and so the plastic does not discharge electricity can damage the entire electronics in the house.
Lightning
Always be that Safety First!
Berezhany, UA
Station: 2224
Litz wire? Although that may have some advantage over solid magnet wire, I have never heard of anyone using that for BT lightning receiver antennas.
(2019-05-06, 20:23)mwaters Wrote: Litz wire? Although that may have some advantage over solid magnet wire, I have never heard of anyone using that for BT lightning receiver antennas.
Litz reduces the proximity effect in wound coils. [My antennas also have spaced turns]. I'm sure the Litz is overkill, but I had a roll of 100/46  wire handy, and it is really good for winding on ferrite rods - far more flexible than single strand magnet wire. Of course, tinning the ends is an exercise on its own, but I hope to get a test set-up running today and we shall see whether the system works well enough to contribute something to the project.
D
(2019-05-07, 09:56)Tinny Wrote: Litz reduces the proximity effect in wound coils. [My antennas also have spaced turns]. I'm sure the Litz is overkill, but I had a roll of 100/46  wire handy, and it is really good for winding on ferrite rods - far more flexible than single strand magnet wire. Of course, tinning the ends is an exercise on its own, but I hope to get a test set-up running today and we shall see whether the system works well enough to contribute something to the project.
D
To remove the insulation from Litz wire, carefully heat the ends to a dull red heat with an alcohol burner and immediately quench  it in alcohol while it is still hot.
Having said that, the receivers may have been designed for close-spaced magnet wire. The Litz may improve or degrade the performance. But I don't know.
