GPS antennea seems to die, is this typical of inexpensive units?
(2022-11-07, 23:23)cutty Wrote:
(2022-11-07, 21:59)cernese Wrote: I've been running a "blue" system since the fall of 2017!
At the end of last month, near end-October-2022, I get a startup sequence where the GPS unit responds and then dies.
First 1 satellite and a few seconds later, a 2nd satellite, and then it stops responding completely.
It was an inexpensive "active antenna 28dB Gain, 3-5VDC, SMA connector" widget and I'm going to order a replacement unit, any suggestions or should I just pick what I find in amazon.com ?
Thanks,
Dan
Hi Dan... have you seen this thread???
I updated the firmware, a voila!  It works again!
Note to others:  I have Windows 10, I mistakenly tried the Windows 8 driver, no go (even though the virtual COM3 port shows up).  Installed Windows 7 driver, that worked.
However, the flash either reports no com ports or failed to enumerate com potrs-- so I edited the .ini file and changed it from 1 to 3 (my device manager shows it as COM3), and it worked first time!
Stations: 2135
RE: GPS antennea seems to die, is this typical of inexpensive units? - by cernese - 2022-11-13, 18:18
