System Blue on a reboot loop
Hi! I am a new user and I have a System Blue with the PCB 19.5 and the firmware version 9.4. Every time I turn it on (with only the power connected to the device), it makes a shorter higher-frequency beep and a longer lower-frequency beep. The Power, Mode, Network and GPS LEDs turn onĀ and stay on for about 15 seconds and then the 2 beeps sound again and the whole thing happens again: the 2 beeps and the lights on. I have already tried flashing versions 9.4, 9.5b1, 10.0b1 and 10.0b2 and there is only a difference in the beeps. I have also tried connecting the System Blue to my local network and used Fing to try and find the IP, with no luck. However, when I connect it directly to my PC via Ethernet, I used Wireshark to get the IP address and I am able to ping it but not able to open its web interface. What can I do to solve my problem?
