Threads: 2
I see from the document that Controller 10.4 has two amplifier input connectors on the board. Is it possible to run two amplifiers off the one controller, say one H and one E field?
Andrew
Threads: 62
(2014-06-01, 22:44)AndrewIC Wrote: Hello,
Andrew
Oh Yes... works great adding boards 13 & 14.
Threads: 2
Thanks my kit with H-field amp just arrived
Threads: 62
(2014-06-21, 13:49)AndrewIC Wrote: Thanks my kit with H-field amp just arrived
Go For It!...
Over here in region 3 we're trying to get all to run H field on amp1 and E field on amp 2, so if they have issues, we can all work with the same "Channel Colors" on displays...
So if they're running E field only, we're suggesting they connect it to amp 2...
