Using the amplifier only
I'm an electronic hobbyist, owning a small weather logger. I just came across the whole documentation of the project and I guess it too expensive for me to establish my own station.
However, I'd like to, at least be able to log the strikes, so I was wondering whether it is possible to use only the antenna and the amplifier and connect its outputs to my 1wire impulse meter via an analog comparator.
The main problem is - will it work without the main board?
I know that the op-amps are digitally or manually controlled through atmega8. What will happen if I don't connect the main board, just assemble the aplifier one. Will it able me to control the amplification manually?
Using the amplifier only - by piotreeek - 2014-08-06, 16:54
RE: Using the amplifier only - by cutty - 2014-08-07, 00:39
RE: Using the amplifier only - by piotreeek - 2014-08-07, 06:18
RE: Using the amplifier only - by RichoAnd - 2014-08-07, 07:20
RE: Using the amplifier only - by piotreeek - 2014-08-10, 10:20
RE: Using the amplifier only - by DelandeC - 2014-08-10, 11:53
RE: Using the amplifier only - by weatherc - 2014-08-10, 12:53
RE: Using the amplifier only - by cutty - 2014-08-10, 14:05
RE: Using the amplifier only - by cutty - 2014-08-10, 23:02
RE: Using the amplifier only - by piotreeek - 2014-08-11, 01:02
RE: Using the amplifier only - by cutty - 2014-08-11, 13:13
