Hardware Problems
(2014-08-17, 12:34)Tobi Wrote: Theoretically it's possible that malformated strings from the GPS chip produce some buffer overflow. But this is only one of a lot of more possibilities.
As you have already connected the serial output, you should enable the debug mode and check the messages there. Hold the blue button for a second while doing a reset. The LCD will show a hint that the debug mode is enabled. Press the blue button again to continue and check your terminal.
Hello Tobi,
i am still working on the same Problem and can“t realy get my controller board running.
The only Firmware Version witch is running and shows a Website is 7.04b.
Al other Firmware Versions are not working on my Hardware.
I can not understand why ?
Now i have the Board in the debug mode an the serial interface is connectet to the hyperterminal so i ca see the log.
How can you help me?
Christian
Hardware Problems - by Christian.Weiss - 2014-08-16, 14:45
RE: Hardware Problems - by Tobi - 2014-08-16, 14:52
RE: Hardware Problems - by Christian.Weiss - 2014-08-16, 15:04
RE: Hardware Problems - by Tobi - 2014-08-16, 15:21
RE: Hardware Problems - by Christian.Weiss - 2014-08-16, 16:04
RE: Hardware Problems - by Benedict.Smith - 2014-08-16, 16:21
RE: Hardware Problems - by Christian.Weiss - 2014-08-16, 16:26
RE: Hardware Problems - by Tobi - 2014-08-16, 17:05
RE: Hardware Problems - by Christian.Weiss - 2014-08-16, 20:02
RE: Hardware Problems - by Tobi - 2014-08-17, 06:03
RE: Hardware Problems - by cweiss - 2014-08-17, 10:04
RE: Hardware Problems - by DelandeC - 2014-08-17, 10:32
RE: Hardware Problems - by Tobi - 2014-08-17, 12:34
RE: Hardware Problems - by cweiss - 2014-08-24, 13:49
RE: Hardware Problems - by PA4EME - 2014-08-29, 22:03
RE: Hardware Problems - by Tobi - 2014-08-30, 08:21
RE: Hardware Problems - by cutty - 2014-08-30, 10:05
RE: Hardware Problems - by PA4EME - 2014-09-07, 17:59
