Missing Part or no longer needed? LF33CV for controller board
Is this part no longer needed or just missing from my RED controller kit?
(2014-09-22, 15:43)Geewizard Wrote: Is this part no longer needed or just missing from my RED controller kit?
The LF33CV transistor regulator is used by the circuitry to provide 3.3 volts to the Controller board.
If you are missing yours, you can get a replacement from Mouser at the following link:
Stations: 808
Thanks. I guess it was just missing then. I use Digi-Key since I have an account there.
Sorry for the missing voltage regulator. Undecided
Buying the regulator at some local electronic distributor should be the fastest and easiest way.
Exclamation System Red no longer for sale JumpingJ 6 42,391 2020-10-19, 10:52
Last Post: africaone
  Interference mode notification needed cbhiii 0 11,321 2017-04-27, 01:59
Last Post: cbhiii
