Reactivating an old Green PCB 6.8 USB - troubles
Do you have the documentation? If not login to the blitzortung site and wander over to Project Area > Compendium then Project Descriptions. Pin 4 of the GPS-DEVICE connector is connected via JP2 to pin 14 RxD of the ATMega so pin 4 on the PCB needs to be fed a data stream, check that JP2 is set correctly. B-)
RE: Reactivating an old Green PCB 6.8 USB - troubles - by allsorts - 2017-07-18, 21:27
  System Green PCB eagle Autodesk files meteolab 0 9,692 2025-01-26, 18:00
Last Post: meteolab
  Replacing the System Blue mini with micro USB connector hazelnut 4 23,489 2022-02-27, 08:40
Last Post: hazelnut
  Testing USB-chargers RichoAnd 3 27,820 2022-02-27, 07:04
Last Post: hazelnut
  GPS troubles with my blue box hazet_CHAM 3 31,410 2017-12-30, 03:23
Last Post: Dale.Reid
