System Blue - Rocker Switch Question
The System Blue assembly instructions refer to a jumper across pins 5 & 6, which was installed on my new System Blue (presumably to allow the firmware to be installed prior to shipment). With this jumper installed, you should be able to power up the board by simply plugging in the USB power connector (no need to wire the switch).
To wire the switch the jumper needs to be removed and the switch wired between the two pins (via plug in header or insulated pins).
Peter
Stations: 1588
RE: System Blue - Rocker Switch Question - by pjb01 - 2016-09-09, 01:21
Question Question about the antena in system Blue BlackRockShooter 7 36,305 2020-08-25, 11:23
  Using the on/off switch with the new Blue enclosure Dale.Reid 7 35,874 2016-11-15, 02:36
Last Post: Dale.Reid
  System Blue Network Interface Question chevyman142000 13 61,600 2016-09-19, 20:21
Last Post: chevyman142000
  Registering new system question.. Aythya 8 43,618 2016-05-12, 07:21
Last Post: Knolau
  Question about System Blue parts. kevinmcc 2 17,039 2016-05-06, 23:52
Last Post: kevinmcc
