E field antenna height
(2017-11-04, 08:26)vk2him Wrote: Thanks Richo for this excellent information ... I operate an amateur radio station at home operating mainly on the 2M band @ 145.175Mhz with 40W - do you think this will cause an issue? I plan to place the e & h antenna as far as possible from the 2m antenna.
I also have solar panels with micro-inverters that communicate over the internal electrical wiring - have you heard of issues caused by power line communications?
My System Blue was posted the other day so I'm getting myself organised in advance.
Regards
Ian
Ian, I used to use Ethernet over power adapters before I had a Blitzortung station, they caused huge amounts of RF noise across a wide spectrum and one of the first things I did was to give them away to someone who lived a good distance from me, I wouldn’t touch them again, I think a lot of radio amateurs have similar views on them.
I have also read of noise problems with solar inverters but don’t have any myself so cannot comment further.
Stations: 878
E field antenna height - by DrRobin - 2016-09-27, 21:23
RE: E field antenna height - by RichoAnd - 2016-09-27, 22:32
RE: E field antenna height - by Ranieri - 2016-09-28, 15:40
RE: E field antenna height - by RichoAnd - 2016-09-28, 17:42
RE: E field antenna height - by Ranieri - 2016-09-28, 18:25
RE: E field antenna height - by RichoAnd - 2016-09-29, 06:40
RE: E field antenna height - by vk2him - 2017-11-04, 06:33
RE: E field antenna height - by RichoAnd - 2017-11-04, 07:38
RE: E field antenna height - by RichoAnd - 2017-11-04, 07:39
RE: E field antenna height - by vk2him - 2017-11-04, 08:26
RE: E field antenna height - by Benedict.Smith - 2017-11-04, 16:31
  Blue e-field antenna question llowrey 2 7,445 2021-07-06, 14:34
Last Post: llowrey
  My E-field antenna setup TomVal 3 12,068 2020-11-05, 15:48
  Can E-field antenna be casted in resin? OH4GRM 3 12,254 2020-06-01, 13:19
Last Post: dupreezd
  E-Field Antenna and 60 Hz power lines waysta 4 23,552 2017-06-09, 23:11
Last Post: radiofarol
  Blue H field Ferrite antenna in L or Delta shape? nellyt 8 48,134 2017-03-30, 03:06
Last Post: Mike6158
