Testing detecting range
(2020-04-13, 09:34)S_beast Wrote: Hello everyone.
Currently I have heard a several lightings in my neighbourhood (around 1km), but it seems that my station is not involved in registering them. Shouls I worry or I did something wrong?
Station 2643.
I also noticed that you specified an E-probe on channel 1 as your only detector. Antenna 1-3 is allocated for H-field (loops, ferrites ) . If you only have the E-probe, it should be on Antenna 4.
To correct this, logon to your BO profile and enter the correct values. Note that antenna 1 corresponds to Input 0 and so forth. Also under dimensions enter the correct values. Hover your mouse over the Dimension box and it will show examples.
On System Blue Inputs 4-5 is not used and must be set to "undefined' as well as any inputs that is not in use.
Testing detecting range - by MooreGeo - 2019-07-26, 16:32
RE: Testing detecting range - by gerbold - 2019-10-25, 22:27
RE: Testing detecting range - by kriu - 2019-10-28, 10:26
RE: Testing detecting range - by rodolfohill - 2019-11-20, 02:07
RE: Testing detecting range - by S_beast - 2020-04-13, 09:34
RE: Testing detecting range - by cutty - 2020-04-13, 12:12
RE: Testing detecting range - by dupreezd - 2020-04-13, 12:34
RE: Testing detecting range - by S_beast - 2020-04-13, 14:17
  Detecting in other Zones? actiopabs94 3 9,065 2021-08-09, 15:56
Last Post: NHSA_Rainer
  Detecting in other Zones? MooreGeo 5 24,397 2017-11-13, 01:02
Last Post: MooreGeo
  Detecting Lightning strikes on the opposite side of the earth ? Michael.Sanders 1 13,094 2014-10-28, 12:01
