Moved Antenna, Now Interference Mode
Hey guys,
I moved my e-field antenna/probe outside yesterday (made a PVC pipe enclosure). It was up in the attic above the garage. Since then, it seems that it is in interference mode more than normal. See below for the numbers that I'm seeing. Let me know what you think, should I move it back in the attic or what?
Thanks!
    • ModeAutomatic
    • SignalsReceived: 1131192, Good: 1129139, Sent: 103399
    • Signal RateLast second: 0, Last 60s: 0.1
    • ErrorsNo GPS: 1, Overflow: 442
Stations: 1591
I took it out of Automatic mode and did some manual settings. See screenshot and let me know what you think. This doesn't mean a whole lot to me, but I'm reading as much as I can to learn what it means.
Thanks!
[Image: xCTNKm9.jpg]
Stations: 1591
  Moved station, lightningmaps still not updated mikaelbrostrom 1 19,562 2025-08-13, 09:08
Last Post: Eric.Wouters
  Moved Posts - Unable to read them mendip_defender 3 27,562 2020-10-14, 19:37
  [moved] German: Order Question starlord 1 32,980 2017-12-14, 07:34
Last Post: starlord
