Moved station, lightningmaps still not updated
Hello
I moved my station and on blitzortung everything looks right but not on lightningmaps, wrong info and location. Something i need to do?
The station in question is  2718
Welcome on the forum. I have upped your status as participant so you have a lot more to read
Also do some searching on forum regarding LMO. is not actively maintained by Tobi (it is a side project and not official)
For up to date data and details you have to use https://map.blitzortung.org/
Regarding location, yes it is fuzzy to preserve privacy of the users. It sets it in a circle a few kilometers wide around your spot and will often change a little inside that circle.  But rest assured that the exact GPS data is used for strike calculations.
  Moved Posts - Unable to read them mendip_defender 3 27,520 2020-10-14, 19:37
  [moved] German: Order Question starlord 1 32,969 2017-12-14, 07:34
Last Post: starlord
  Moved Antenna, Now Interference Mode chevyman142000 1 23,601 2016-09-27, 13:58
Last Post: chevyman142000
