Red system 7.4 to 8.1 network no good !
I have the RED system with version 7.4 which works fine. I wanted to move to version 8.1 but after 20 minutes there is no network connection and asked me to check the network cable. I tried version 8.0 and 8.1, the same finding, network problem !!!
Have you an idea about this failure.
Thank you and read you
JAK
I handed version 7.4 and no problem!
I don't know why this happened. Can you please update to 8.1 again and stay there for a while? Some debug output can help too. Can you provide some information about your network (i.e. DHCP, basic network scheme etc.).
(2016-09-27, 10:17)Tobi Wrote: I don't know why this happened. Can you please update to 8.1 again and stay there for a while? Some debug output can help too. Can you provide some information about your network (i.e. DHCP, basic network scheme etc.).
Many many thanks
My network : 192.168.1...
Network system Red is 192.168.1.40 ( same red version 7.4 )
DHCP : on
No probleme with 7.4 version but with 8.0 and 8.1 its ok for 20 minutes and after network down !!!
To day at 12:00 UTC i put 8.1 version and wait .
See you at the next , many thanks Tobi
Many many thanks
DHCP : on
After 18 minutes , all ok , look the photo.
tks
There seems to be a memory allocation problem. It's not directly related to the network connection. I will investigate.
PS: Please leave the station running this way! Thanks!
(2016-09-27, 12:36)Tobi Wrote: There seems to be a memory allocation problem. It's not directly related to the network connection. I will investigate.
OK Tobi, thanks
my station works since 27/09/16 at 12:40 utc after reset ( black button ).
see you
JAK
OK Tobi, thanks
see you
JAK
after ten minutes, on the display: Check network cable connection... networks down...
OK Tobi, thanks
see you
JAK
Tobi, its OK now, after 30 minutes with network down without touching anything, its OK !!!
Many thanks
best regards
OK Tobi, thanks
see you
JAK
Many thanks
best regards
Bonjour et merci Tobi ça fonctionne super bien.
All OK many thanks.
The problem occurs only when the station is registered for more than one region in combination with compression. It will be fixed in the next firmware.
(2016-09-28, 06:55)Tobi Wrote: The problem occurs only when the station is registered for more than one region in combination with compression. It will be fixed in the next firmware.
Helle Tobi,
I just installed version 8.2 and it works great. Tobi thank you very much.
Regards
  Network not working on System blue Ldarax 0 13,890 2020-06-05, 15:33
Last Post: Ldarax
