E field antenna height
I have just received my system blue and going to make E field and H field antennas.  I have a couple of questions:
What is the minimum height for the E field antenna?
If I mount the system blue in my shed then I doubt I can get the E field antenna above 5m.
If I put the E field antenna in my house the E field antenna will have to go on my wind speed/direction mast, the wx station transmitter is located about 4m below, will this be okay as the speed/direction is just low frequency switch contacts?
The H field antenna is going to be two ferrite rod antennas, these will probably be in the loft.  I assume that these are both mounted horizontally, one facing east-west and the other north-south?
If I put my system blue in a remote location and use a wifi router what is the minimum recommended distance from system blue to wifi?
Sorry for the stupid basic questions but I would like to get it installed in the best place first time.
Thanks
Robin
E field antenna height - by DrRobin - 2016-09-27, 21:23
RE: E field antenna height - by RichoAnd - 2016-09-27, 22:32
RE: E field antenna height - by Ranieri - 2016-09-28, 15:40
RE: E field antenna height - by RichoAnd - 2016-09-28, 17:42
RE: E field antenna height - by Ranieri - 2016-09-28, 18:25
RE: E field antenna height - by RichoAnd - 2016-09-29, 06:40
RE: E field antenna height - by vk2him - 2017-11-04, 06:33
RE: E field antenna height - by RichoAnd - 2017-11-04, 07:38
RE: E field antenna height - by RichoAnd - 2017-11-04, 07:39
RE: E field antenna height - by vk2him - 2017-11-04, 08:26
  Blue e-field antenna question llowrey 2 7,462 2021-07-06, 14:34
Last Post: llowrey
  My E-field antenna setup TomVal 3 12,102 2020-11-05, 15:48
  Can E-field antenna be casted in resin? OH4GRM 3 12,275 2020-06-01, 13:19
Last Post: dupreezd
  E-Field Antenna and 60 Hz power lines waysta 4 23,585 2017-06-09, 23:11
Last Post: radiofarol
  Blue H field Ferrite antenna in L or Delta shape? nellyt 8 48,176 2017-03-30, 03:06
Last Post: Mike6158
