H-field pre-amplifier PCB and ferrite antennas
For the system blue H-field pre-amplifier PCB - a few questions:
1.  Do the ferrites connect between just the a and b ports with the ground port left unconnected unless additional shielding is needed?
2.  Is there any polarity to the ferrites - I see references to one enameled wire with a knot being + or is this for the old system only.
3.  For ferrite antennas do the PCB jumpers need to be soldered (closed).
Thanks in advance!
A single ferrite antenna will connect to A1 and A2, and the ground is there for shielding if you decide to shield the antenna.
Polarity does not matter.
No the PCB jumpers do not need to be soldered closed.
  home made ferrite antennas opadavis2 10 45,159 2017-07-23, 19:34
Last Post: pasense
  Blue H field Ferrite antenna in L or Delta shape? nellyt 8 48,127 2017-03-30, 03:06
Last Post: Mike6158
  H-Field Ferrite Rod Antena Parameters dieron 2 15,171 2017-02-28, 19:10
Last Post: RichoAnd
Photo H field ferrite shielding orion_jb2001 5 32,167 2015-01-30, 03:58
Last Post: orion_jb2001
  2nd H-Field Amplifier meaningful? CRogoza 1 12,796 2014-06-27, 19:24
Last Post: RichoAnd
