2020-11-16, 23:45
User Name samsam
Station Number 2859
Region: Europe, UK
Thanks,
User Name samsam
Station Number 2859
Region: Europe, UK
Thanks,
2020-11-16, 23:45
User Name samsam Station Number 2859 Region: Europe, UK Thanks,
2020-11-17, 04:28
2021-01-03, 13:21
User Name for Forum: uk52rob
Station Number: 2876 Region: Eurpoe/United Kingdom
User Name for Forum: Psynosaur
Station Number: 2884 User Number: 2278 Region: Africa/South Africa Forum operator status station not listed in https://www.lightningmaps.org/
2021-01-23, 16:40
(2021-01-23, 14:19)Psynosaur Wrote: User Name for Forum: PsynosaurRe: Lightningmaps.org -- You might refer to this post: https://forum.blitzortung.org/showthread...1#pid23501
2021-02-02, 21:27
User Name FJTO Station Number 2511 Region: Europe Thanks
2021-02-18, 23:28
User Name: werk_ag
Station Number: 1045 Region: Europe Only have access to public forum...
2021-03-08, 01:46
User Name for Forum: MASHEP
Station Number if you have one: 2892 Region: Oceania Forum operator status not upgraded.
2021-03-16, 21:27
User Name: Art_Brown
Station 2285 USA/Caifornia Sataion not listed on list or shown on map at https://map.blitzortung.org/#12.41/37.73743/-121.93404
Stations: 2285
(2021-03-16, 21:27)Art_Brown Wrote: User Name: Art_BrownHello Art: Your station DOES NOT SHOW because you are misconfigured. https://www.blitzortung.org/en/login.php You have selected 'anonymous' on your station configuration page, which prevents ANY of your station data being displayed. You are sending signals, and they are being recorded, etc, but your data is NOT visible because of your selection. ![]() While you are changing the Anonym: Y to Anonym N, please configure your antennas etc correctly. https://forum.blitzortung.org/showthread.php?tid=2863 Your system signals are processed as 'server's best guess' without the correct antenna configurations. Also note you have your optional filters set so NO frequency higher than 25kHz will be processed. Unless you have extreme noise at normal settings above 25kHz, you are NOT sending best data with the low end bandwidth only. Strongly suggest turn them off, and re-optimized your station. As to other questions regarding data in that above thread, (tid 2863) please note the ONLY official data is what is on the OFFICIAL site, blitzortung.org. NO Adjunct site will present correct, up-to-the moment data, and statistics aren't computed 'officially' and will be at variance with 'officially' derived data. |
« Next Oldest | Next Newest »
Possibly Related Threads… | |||||
Thread | Author | Replies | Views | Last Post | |
Station List not showing any United Kingdom stations | dgoadby | 2 | 6,239 |
2019-04-15, 16:35 Last Post: dgoadby |
Removing Station 723 from list | Ian.Cooke | 5 | 17,768 |
2015-02-03, 20:39 Last Post: Toxic |
