Account Setup
Can someone tell me what there looking for here in the Data Base Information?...
Assign a new station:  (Processor-ID)
Where do I find my processor ID....
is it the HLK/SYSCLK/PCLKs  and then what looks like an IP address followed my Mhz ???
Thanks Much,
(Manual entry by admin:  Station 2334)
Stations: 2334, 2382
(2018-12-03, 22:50)Mike Wrote: Can someone tell me what there looking for here in the Data Base Information?...
Thanks Much,
Mike your Device-ID/processor-ID is that long number, 6 groups of 4 numbers.
Just copy and paste, but make sure you don't get any leading or trailing spaces.
Oh, and turn Auto Refresh off in the  top right corner, otherwise you will have a hard time selecting the string and copy.
Still lost....
Are we first looking at my Controller information that pops up when you put in the IP address of the System Blue Board....
If so, I don't see that large of a group of numbers...
(2018-12-03, 23:04)Mike Wrote: Still lost....
Sorry, Log on to the controller, Status page. Scroll down to Controller/CPU
I'm there, but no 6 groups of 4 numbers....
I have:
Firmware: Rev.9.0b1 BLUE/May 13 2018 10:49:24
Hardware: Rev. 19.4 (PCB-id 70)
HCLK/SYSCLK/PCLKs: 168/168/41/84 MHz
CPU: 59% 34.2 C, 3.26V
Max. Memory usage: 118kB + 65kB for Signals
Signal Buffers: 15
Input Voltage. 4.86V
(2018-12-03, 23:25)Mike Wrote: I'm there, but no 6 groups of 4 numbers....
I have:
Signal Buffers:  15
Now that is weird. It should be just below Hardware.
Maybe one of the Developers will chime in.
Sorry, I can not be of more assistance.
PS. I do see you are running on a a Beta release firmware. Try updating to the latest release 9.1.
By all means, upgrade! Take note of the warnings.
This is what mine looks like, FWIW.
Controller / CPU
Firmware. Rev. 9.1 BLUE / Aug 8 2018 21:10:54
Hardware  Rev. 19.5 (PCB-Id 7/0)
Device-ID  1F00-0000-0000-0000-0000 [private; edited by me]
HCLK / SYSCLK / PCLKs168 / 168 / 42 / 84 MHz
CPU 57%, 33.2°C, 3.25V
Max. Memory usage. 118kB + 65kB for Signals
Signal Buffers. 34
Input Voltage  5.00V
Network
Well, I've looked over the Mac and Windows firmware install and the instructions fall off of a cliff...
First one says to upgrade firmware via web interface and follow the prompts...."What Web Interface"
Second calls for a single wire debug device....???????
Third calls for flashing new firmware over the USB connector via the DfuSe .....but there's no USB connector on the Blue Board.....
Help.....
(2018-12-04, 01:54)Mike Wrote: Well, I've looked over the Mac and Windows firmware install and the instructions fall off of a cliff...
Help.....
The web interface is what you see when you log on to the controller.
Tools page. Firmware.
Did you download the version 9.1?
I can download 9.1...it appears as a .bin file
But I do not have any Tools page....in my controller page..
I have login, Status and About.....those are the only tabs at the top of the page
Station 0
FW 9.0b1PCB 19.4/H1/E1
SYSGPSNETAMPSIG0/s00:00:46
Login
Status
About
Auto Refresh
(2018-12-04, 02:49)Mike Wrote: I can download 9.1...it appears as a .bin file
Station 0
Login
Status
About
Auto Refresh
Can you post a screen shot?
Station 0
Login
Status
About
Auto Refresh
Mike-
The problem is that you have enabled "Need Authentication" under Web Interface in the settings tab and you are viewing the Status page as a guest - in other words you have not logged in to your controller yet so most stuff is hidden including the Device ID numbers you need.
To make this work, you need to press the Login link and then login using the username and password you created initially. Once you're logged in you will be able to view the Device ID numbers you need. Unless you specifically want to user that login facility, you can disable the "Need Authentication" . Most of us don't have it enabled as we don't have our controller's status page exposed to the internet using port forwarding.
Hope that helps. Cheers
Stations: 2039
Ok, now we're getting somewhere....Vk2him, you were correct...I know have the full list as described....
Seems, putting in the INCORRECT PASSWORD does not flag it as incorrect and I was assuming that I was actually logging in with the CORRECT PASSWORD....
Woke up at 1:45 in the morning still thinking about this and happened to get up and check this form and you guys came through....Thank You, Thank You.....but I'm going back to bed.....
Good Morning,
I've updated the firmware to 9.1..... everything seems so simple with a little help from "Friends of the Forum"
Thanks Very Much... I'm sure I'll have more questions down the road...
Eagle River
Finding my user #XXXX and station #2334 after logging into the Contributors site..... I see myself on the Users List but not on the Stations List...
and how do I know if I'm a fully reporting station....
Thanks Again,
Eagle River
(mod:removed user#-public thread-)
(2018-12-04, 15:11)Mike Wrote: Finding my user #XXXX and station #2334 after logging into the Contributors site..... I see myself on the Users List but not on the Stations List...
Thanks Again,
Eagle River
Not sure this is complete issue... but if you have 'anonymous' "Y" on your station config page,  Make sure it is "N".
You may also be a 'victim' of the new server databases and processing still a bit groggy ... additionally it may take a couple of hours
to update presently... I'm not sure what schedule he has it running on.,.. or which regional servers he's working on.
Thanks Again,
Eagle River
Check your Email ...
Cutty,
Anonym has always been set at "N"....
  Antenna setup. josecmorales 1 17,429 2021-07-19, 16:23
  My E-field antenna setup TomVal 3 28,737 2020-11-05, 15:48
Smile System blue antena setup site. bartasmosina 7 53,529 2019-05-10, 15:06
Last Post: mwaters
