Station statistic data correct?
Hello
Since a few days the servers seem to be at work again.
However, I wonder why the column "number of signals" in the station list displays the same figures across all stations in the list. Is this correct or how is this to be interpreted?
Thanks for explanation(s).
Cheers and regards
Hans
Cheers Hans
Stations: 1671
(2018-12-19, 10:48)hazet_CHAM Wrote: Hello
Cheers and regards
Hans
I assume you are talking about Lightning Maps Org... Blitzortung seems ok....
that's probably because the new upgraded processing between BT and LMO are still been mpklemented on LMO for those tables.
The New Data presentation from the main servers  will present a few issues as they are fully implemented and installed., especially
of a new or revised parameter computation is concerned..
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 13,579 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  Empty statistic page hazet_CHAM 2 21,511 2021-09-06, 22:10
  Empty statistic page hazet_CHAM 0 11,622 2021-08-18, 15:27
Last Post: hazet_CHAM
  statistic display data discrepancies hazet_CHAM 0 16,603 2016-11-15, 09:29
  strange station statistic data hazet 5 43,886 2015-07-13, 15:16
Last Post: hazet
