interference with Ham Radio.
Dear team
I have a question.
I have the mini version at home and works nicely.
But I am also as Hamradio transmitting on 136 kHz 474 kHz and HF and VHF frequencies. I noticed that this gives a disturbance on the mini receiver.
Is this Harm full for the preamplifier , so I should disconnect the preamplifier  or using band pass filter for the mini or is this ok and the AGC can handle it.
The output power of the transmitters is  max 100 watt.
ok8leo
(2025-07-24, 08:28)Ok8leo Wrote: Dear team
I have a question.
ok8leo
Is your preamp the 23.1?  If so, see the schematic:
The signals from the antennae smack immediately into a substantial diode chip.  It absorbs everything in excess of maybe 1.4 volts.   So there is no danger of your damaging the preamp.
AA2KW - Station 3205
(2025-08-11, 01:40)oppedahl Wrote: ...
Thanks for the schematic!
Where did you find it? I looked around for it and didn't find it right away.
D
(2025-08-11, 01:40)oppedahl Wrote: [quote pid="27250" dateline="1753345722"]
Can you tell me what J1 and J2 are for?
D
[/quote]
See this discussion.  Apparently you leave them open if you are using ferrites and close them if you are using air core loops.
(2025-08-11, 01:40)oppedahl  Thanks a lot  for your feedback Have a nice day Wrote:
I have a question.
ok8leo
  100 watt ham transmitter near a blue davidsaroff 9 54,332 2020-10-19, 16:35
Last Post: braind
  SOLVED: Identifying interference with oscilloscopes and software-defined radio djhuft 23 162,968 2017-08-29, 04:58
Last Post: Karate_kid
  NeB Q: Will nearby FM Radio Cell towers cause problems br1ght 2 27,002 2015-09-18, 20:53
Last Post: br1ght
