GPS hosed
Station 2707 status: Bad GPS. I replaced the GPS antenna. There was overhead lightning, nearby strikes. The GPS section of the station web interface shows no 1PPS, no satellites. Before the storm, there were 5-6 satellites on the polar graph, position data, everything was working. If I need a new board, I will connect the grounding jack to earth ground.
