Blitzortung Lightning Data does not show up in LightningMaps website
Bug
apparently ive noticed a bug in lightningmaps.org where it no longer displays data from the testing and Blitzortung sources, even while the sources are turned on in the menu. this must be a bug here and its really annoying that i cant see the thunder fronts on the other two sources. i dont know if this applies to this forum but im reporting it for the LightningMaps website which redirected me here.
As written over and over and over already by Cutty and others (please do some search and reading) LM is not maintained anymore since months because the database from Blitzortung (the official one) is changing, evolving. Tobi has not much time and won't adapt his LM experiment  as long as the main databases are not stable.
This is the only realtime map https://map.blitzortung.org/
  Best way to integrate Blitzortung lightning data into a custom web application? kaileyketchum 0 406 2026-07-01, 15:25
Last Post: kaileyketchum
  How Accurate is Real-Time Lightning Tracking on Blitzortung? kev_rm 7 19,375 2026-01-22, 06:11
Last Post: numbNinja
  What is the impact of urbanization on lightning data collection accuracy? sophia2005 4 20,960 2025-09-17, 04:51
Last Post: sophia2005
  White dot doesn't show up on my station Geewizard 1 19,350 2025-07-01, 07:34
Last Post: Kets_One
  Problems displaying historical lightning data? Rain 4 33,605 2025-06-12, 15:13
Last Post: GeezerD
