Accuracy
I have a question, and I don't mean to be antagonistic.  I am a sailor. I have been sailing around the globe for many years and I try to use all of the available information to me to inform my decision making.  In the tropics,  particularly near the equator, lightning is a very real risk.  I have had three strikes within 200m of me, and a direct strike is on the order of $50,000USD and 1 year of time to repair.  I know four friend boats that have been hit.
My question is this - and please if you have something to contribute, talk about independent observations to calculated results.  Not about "here's the math for the calculated result"
How is  accuracy measured with this platform?  In simple terms - if there is a set of data that represents real actual strikes  or cloud-to-cloud - position and time that we've used to validate?
As a rule we don't compare ourselves to the professional piad for services as we are just a group of hobbiests.
I reffer you to a post made some time ago,
https://forum.blitzortung.org/showthread...8#pid18468
Station 2828 - LM or BT
Stations: 2828
Hello Sailor Kev!
A sailboat is pretty much just a well-grounded lightning rod in the flattest possible place, rigged up so it'll float, right? What kind of lightning protection do you use onboard?
If you are talking about detecting lightning strokes from a sailboat, you have some relatively unique needs that are not likely well served by Blitzortung. Blitzortung is a detection network, connected by low-latency internet. I think you would be better served by a single station receiver and detector on your boat, and even there your unique needs, such as the mobile nature of  your antenna, will require special support compared to a stationary installation.
Is it even better over the lifetime of the hull to have a good air terminal, grounding conductor and connections, and grounding plate? Like, in California, it's rather more economical to bolt your house to your foundations than it is to buy the state earthquake insurance they offer, and I can give you four reasons why...
That said ..
Coverage in the tropics, pretty much anywhere south of the Tropic of Cancer and into the southern hemisphere is very poor. Blitzortung is primarily a northern hemisphere, temperate region sort of thing, because of the location of the entirely volunteer detectors and the non-commercial nature of the entire endeavor, as mendip_defender mentioned.
Anecdotally, Blitzortung accuracy is pretty good. I was able to use Blitzortung dynamic maps around my small town in Colorado as a proxy for seeing the flash of lightning. After that, I was able to count seconds to estimate rough distance, and verify both distance and rough bearing when I heard thunder. It was fun.
Compared to other lightning detection and location services, blitzortung has some characteristics that you would have to be aware of. Unlike Blitzortung, other services may detect strokes other than Ground to Cloud or Cloud to Ground. When you compare Blitzortung detections to other services, you are likely to see about twice as many strokes in the other services as you see in Blitzortung, because of that. Again anecdotally, I've done this is California for strokes in the Diablo Range and east toward the Sierras, and of the strokes that were reported by both Blizortung and the "other" service accuracy was still good.
D
D
(2025-11-02, 19:54)GeezerD Wrote: Coverage in the tropics, pretty much anywhere south of the Tropic of Cancer and into the southern hemisphere is very poor.
100% right, unfortunately. Trying to improve the network and detection ratio in Africa for exemple is a real challenge.
I would not rely on Blitzortung (yet   Smile ) for safe sailing
   Marc
Stations in Africa: 3084, 3111, 3112, 3113, 3155, 3156, 3157
Still in Europe: 673, 3158, 3159
  About the lightning location accuracy of blitzortung.org kazu 5 18,731 2024-07-15, 14:37
Last Post: Olivier_FR67
  Sky News - accuracy of data adamparker 1 15,318 2021-05-12, 12:32
  Accuracy question edbett 5 40,749 2018-06-09, 15:22
Last Post: edbett
  what is the greatest accuracy possible with the system? clif9710 0 15,176 2014-08-30, 20:11
Last Post: clif9710
