Hi everyone,
I’ve been exploring how lightning detection systems work and wanted to share a simple DIY approach for beginners who are interested in experimenting with electromagnetic detection and real-time monitoring.
How Lightning Detection Works (Basic Idea)
Lightning strikes generate electromagnetic pulses (EMP) across a wide frequency range. These signals can be captured using:
By analyzing the signal strength and timing, it’s possible to detect and even estimate the distance of lightning activity.
Basic Components You Can Use
For a simple setup, you can start with:
Simple Workflow
Possible Enhancements
Once the basic system works, you can expand it by:
Challenges I Noticed
Would love to hear from others who have tried building similar systems or experimented with RF-based detection. Any tips on improving signal accuracy or filtering noise would be really helpful!
Discussion
Has anyone here built a custom lightning detector from scratch?
What frequency ranges worked best for you?
Any recommended modules or approaches for better accuracy?
Looking forward to your insights!
- RF antennas
- Signal amplification circuits
- Microcontrollers for processing
- A microcontroller (like Arduino or Raspberry Pi)
- RF receiver module or lightning sensor module
- Antenna (simple wire antenna works for testing)
- Optional: OLED/LCD display for output
- Power supply + basic passive components
Simple Workflow
- Capture electromagnetic signals using the antenna
- Feed the signal into an RF module or detection circuit
- Process the signal using a microcontroller
- Display or log the detected activity
- Logging data to a cloud platform
- Adding GPS for location-based tracking
- Integrating with weather APIs
- Building a network of detectors for triangulation
- Filtering noise from real lightning signals
- Improving detection range and accuracy
- Handling interference from nearby electronics
Discussion
