System Blue Basic - Indicator Panel for Enclosure?
I had look at the Mini boards as posted by Egon. It looks like he did some modifications to the layout and added a header to connect external leds on the 22b boards.
I do not have a mini, but it looks like the spacing is such that you can solder a pin header in there and then use a ribbon connector to plug in. The other end can the be connected to Leds. Yes, I will not solder directly to the board, but use a header.
The header does provide both +3.3v  with a load resister and gnd. See schematic.
I would use the lowest current draw led's I can get, as normally each led has it own load resister.
Dries
!! - by cutty - 2025-05-14, 09:37
RE: System Blue Basic - Indicator Panel for Enclosure? - by dupreezd - 2025-05-14, 20:47
  The signal data is still not updating on the online panel Svarshdrgdgchik911 5 18,012 2025-10-04, 18:22
Last Post: GeezerD
  Printing 3D casing for Blue-Basic Kellogs 3 23,698 2025-07-05, 15:13
  System Blue Basic availability? G3WGV 19 50,331 2025-07-04, 15:02
Last Post: carseman
  How to order system blue-basic? Kellogs 3 56,022 2025-04-20, 00:09
Last Post: DrFX
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 51,445 2025-04-19, 23:25
Last Post: DrFX
