System Blue Basic - Indicator Panel for Enclosure?
(2025-05-14, 22:16)dupreezd Wrote: Digging deeper into the schematic, I do notice there is already provision made for a 1K load resistor per individual LED. I dont know if the board comes with the resistors pre-installed, but they are 0603 SMD's, so not to difficult to solder on if not already there.
It appear the 2.2k resistor is for the Power On led going to pin 5.
I would be very careful not to short pin 7 (+3V3-C) to ground.
I'm pretty sure those are the 'onboard' LEDs, installed. DrFx says they're 'in middle of board'... can't see 'em when in enclosure... wants to install panel mount... when I've more time maybe... gettin' old, Dries... Sad
I've attached two pictures in the links provided they are high resolution of the Blue Basic. Open the image if a separate tab and zoom in if you need to see more details.
[Image: 02-Blitzortung-Blue-Basic-High-Resolution.jpg]
[Image: 01-Blitzortung-Blue-Basic.jpg]
[Image: 03-Blitzortung-Blue-Basic-Close-of-Chips.jpg]
!! - by cutty - 2025-05-14, 09:37
RE: System Blue Basic - Indicator Panel for Enclosure? - by DrFX - 2025-05-18, 02:12
  The signal data is still not updating on the online panel Svarshdrgdgchik911 5 18,014 2025-10-04, 18:22
Last Post: GeezerD
  Printing 3D casing for Blue-Basic Kellogs 3 23,703 2025-07-05, 15:13
  System Blue Basic availability? G3WGV 19 50,342 2025-07-04, 15:02
Last Post: carseman
  How to order system blue-basic? Kellogs 3 56,026 2025-04-20, 00:09
Last Post: DrFX
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 51,448 2025-04-19, 23:25
Last Post: DrFX
