Can no longer log into System Blue Controller, Web Brouser Interface
First you need to make sure that the IP address you are pinging is the IP address of your blitzordung. It would be best to use a port scanner or simply disconnect the Ethernet device while pinging. The second step is to scan for open ports on the identified address to make sure that the http port (80) is open. I suspect that you may have simply disabled the web server while setting something else up.
Cheap routers like Linksys etc. also tend to get confused when using DHCP and IP/MAC relationships etc. Maybe you're also setting up a static IP/MAC mapping?
(2025-05-19, 01:32)W2PJ-WX Wrote: Blitzortung Community:
I ran into an unexpected problem today.  While trying to fine tune gain and threshold settings I lost the ability to log into the user interface of my System Blue controller using edge.
Station ID: 2110
Controller:  19.3
I have FW version 11.0b3
I lost the ability to log into the controller after a system blue reboot.
Anyone seen this behavior before?
The address I was using stored in my favorites was "http://192.168.1.110/index.cgi?action=status
Trying to log in I get this message on my Edge Brouser and Firefox Brouser:
192.168.1.111
After trying several times and getting confused... I rebooted manual system blue with the on off switch.  No Luck.
Then rebooted the router.  No luck.
Checked the IP address of System Blue on my LINKSYS router.  I could not find Blitzortung, so I performed a clear network map and another reboot of the router.
This time the router saw Blitzortung (new address  192.168.1.111).  Tried that.  No Luck.
Pinged address from a command window and got the following response:
C:\Users\Owner>ping 192.168.1.111 refused to connect
Pinging 192.168.1.111 with 32 bytes of data:
Reply from 192.168.1.111: bytes=32 time=1ms TTL=255
Reply from 192.168.1.111: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.1.111:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 1ms, Average = 0ms
Rebooted computer.  No Luck.
Does anyone have an idea of what my next step might be to resolve this problem?
I read on chat GPT an option to do the following (Steps 4 and 5 below) , but I do not trust it unless there is documentation from Blitzortung with specific instructions and it is the recommended next step.
I hope an expert on the forum can recommend the correct next steps, and if they are complex references to needed documentation, or another thread that explains the next steps in detail.
From Chat GPT:
4. Force a Factory Reset (if needed)
If all else fails, your controller’s web server might have misconfigured settings or crashed.
  • Hold down the reset button on the System Blue controller (you may need a paperclip) for 10–15 seconds during power-up.
  • This should restore default network settings (DHCP enabled).
Then recheck your router for the new IP assignment and try again.
? 5. Firmware Recovery Option
If the reset doesn’t help and the controller is unresponsive to HTTP but still pings:
  • Connect to the controller via USB and use the Blitzortung update tool from their site.
  • This lets you reflash or repair the firmware manually.
Blitzortung firmware + tools are available at:
? https://www.blitzortung.org/en/compendium.php
Maybe step 4 or 5 can be performed remotely as I have the FW version that supports remote / auto firmware updates?  Maybe re-load FW version " 11.0b3"?
Thoughts or recommendations?
Best regards and thanks in advance.
Pete - W2PJ
Jarek R,
Station: 2527
RE: Can no longer log into System Blue Controller, Web Brouser Interface - by Station_Roko - 2025-05-19, 05:52
! - by cutty - 2025-05-19, 17:06
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 52,135 2025-04-19, 23:25
Last Post: DrFX
  Question about web interface williammurdock 3 13,673 2024-08-10, 08:33
Last Post: DelandeC
  Can't Log In k2ors 2 14,780 2024-07-18, 19:32
  cannot log in opadavis2 5 43,607 2019-09-16, 13:19
  System blue web page fails EA3BNF 5 45,114 2017-06-03, 06:55
Last Post: EA3BNF
