Request to correct the position of station on the map www.lightningmaps.org
(2025-05-02, 07:18)Station_Roko Wrote: Hello, dear colleagues.
After several years of working in the previous location, I finally moved the 2527 station to a new place, which was also an opportunity to update the firmware to the latest stable version. I hope that the new location will be much more beneficial due to less industrial external interference. At the same time, I would like to ask for an update of the display of my 2527 station's position on the www.lightningmaps.org map. It seems to me that many people still use this map and the fact that this small circle is not in the right place causes me discomfort Wink
Thank you in advance and best regards.
Hi, I'm also have the same question.
My address is now correct on Blitzortung, but not on Lmaps.
I have moved ca 80-90 Km away from last adress.
I would like to change psition on map, and get the lightningalerts to trig correctly.
Regards Asbjørn Aamot
Norway/Bygstad (1028)
Stations: 1028
RE: Request to correct the position of station on the map www.lightningmaps.org - by Asbjorn.Aamot - 2025-07-02, 16:46
  Station Moved Country and Showing Wrong on LightningMaps Dave.Auld 5 6,671 2026-02-14, 21:27
Last Post: Dave.Auld
  station 3021 in https://www.lightningmaps.org jeanse 1 19,464 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 26,791 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 24,512 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 16,904 2024-07-01, 07:29
Last Post: Blubbel
