Threads: 15
Blitzortung Community:
I ran into an unexpected problem today. While trying to fine tune gain and threshold settings I lost the ability to log into the user interface of my System Blue controller using edge.
Station ID: 2110
Controller: 19.3
I have FW version 11.0b3
I lost the ability to log into the controller after a system blue reboot.
Anyone seen this behavior before?
The address I was using stored in my favorites was "http://192.168.1.110/index.cgi?action=status
Trying to log in I get this message on my Edge Brouser and Firefox Brouser:
192.168.1.111
After trying several times and getting confused... I rebooted manual system blue with the on off switch. No Luck.
Then rebooted the router. No luck.
Checked the IP address of System Blue on my LINKSYS router. I could not find Blitzortung, so I performed a clear network map and another reboot of the router.
This time the router saw Blitzortung (new address 192.168.1.111). Tried that. No Luck.
Pinged address from a command window and got the following response:
C:\Users\Owner>ping 192.168.1.111 refused to connect
Pinging 192.168.1.111 with 32 bytes of data:
Reply from 192.168.1.111: bytes=32 time=1ms TTL=255
Reply from 192.168.1.111: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.1.111:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
Rebooted computer. No Luck.
Does anyone have an idea of what my next step might be to resolve this problem?
I read on chat GPT an option to do the following (Steps 4 and 5 below) , but I do not trust it unless there is documentation from Blitzortung with specific instructions and it is the recommended next step.
I hope an expert on the forum can recommend the correct next steps, and if they are complex references to needed documentation, or another thread that explains the next steps in detail.
From Chat GPT:
4. Force a Factory Reset (if needed)
If all else fails, your controller’s web server might have misconfigured settings or crashed. - Hold down the reset button on the System Blue controller (you may need a paperclip) for 10–15 seconds during power-up.
- This should restore default network settings (DHCP enabled).
Then recheck your router for the new IP assignment and try again.
? 5. Firmware Recovery Option
If the reset doesn’t help and the controller is unresponsive to HTTP but still pings: - Connect to the controller via USB and use the Blitzortung update tool from their site.
- This lets you reflash or repair the firmware manually.
Blitzortung firmware + tools are available at:
? https://www.blitzortung.org/en/compendium.php
Maybe step 4 or 5 can be performed remotely as I have the FW version that supports remote / auto firmware updates? Maybe re-load FW version " 11.0b3"?
Thoughts or recommendations?
Best regards and thanks in advance.
Pete - W2PJ
Threads: 15
Note: The message I get when I enter the address into my browser(s) is: "Hmmm... can't reach this page 192.168.1.111 connection refused"
Threads: 15
Also please note that my System Blue continues to detect and report signals and strokes, but I can no longer change any of the current setting for gains and thresholds and or filters as well as observe real time channel stats, noise level and see signals as I cannot log into the controller user interface! Again, any help would be appreciated.
If the solution is a firmware update, now might be a would a good time to give the automatic Update triggered by the Server a try??!!
Again, I have FW version 11.0.b3 installed.
Threads: 3
2025-05-19, 05:52
(This post was last modified: 2025-05-19, 05:57 by Station_Roko.)
First you need to make sure that the IP address you are pinging is the IP address of your blitzordung. It would be best to use a port scanner or simply disconnect the Ethernet device while pinging. The second step is to scan for open ports on the identified address to make sure that the http port (80) is open. I suspect that you may have simply disabled the web server while setting something else up.
Cheap routers like Linksys etc. also tend to get confused when using DHCP and IP/MAC relationships etc. Maybe you're also setting up a static IP/MAC mapping?
(2025-05-19, 01:32)W2PJ-WX Wrote: Blitzortung Community:
Station ID: 2110
Controller: 19.3
192.168.1.111
From Chat GPT:
If all else fails, your controller’s web server might have misconfigured settings or crashed.- Hold down the reset button on the System Blue controller (you may need a paperclip) for 10–15 seconds during power-up.
If the reset doesn’t help and the controller is unresponsive to HTTP but still pings:- Connect to the controller via USB and use the Blitzortung update tool from their site.
Pete - W2PJ
Jarek R,
Station: 2527
Threads: 64
2025-05-19, 11:48
(This post was last modified: 2025-05-19, 11:54 by cutty.)
Pete,
I'd suggest a thorough reading of
https://docs.lightningmaps.org/station-o...e/#network ... what stuff does.
https://docs.lightningmaps.org/station-o..._recovery/ attempts to fix.
One possible very simple 'glitch'.... Your browser may assume you want an SSL connection, which will be refused. Make sure you're attempting to connect at HTTP://192.1.x.xxx" NOT https:// My browser started that 'thinking for the operator' crap with a recent update...
OTHERWISE:
It appears that your only recourse is a factory reset. Especially if you've inadvertently disabled the webserver.
For this you'll need physical access to the controller so you can push some buttons.
once accomplished,
The factory default address will be 192.168.1.235, and all settings will return to factory fresh.
If you still can't find it after all the options, including security, passwords, etc are 'factory', you may have to look outside the Blitzortung system for the issue.
Those links above give suggestions, info, and procedures for possible scenarios re: can't connect, etc, ( including using the rarely mentioned enter "http://blitzortung" in the browser, which might not work in all network setups . May not work if have more than one BT system active on your network...)
Threads: 64
(2025-05-19, 11:48)cutty Wrote: Pete,
OTHERWISE:
once accomplished,
Those links above give suggestions, info, and procedures for possible scenarios re: can't connect, etc, (including using the rarely mentioned enter "http://blitzortung" in the browser, which might not work in all network setups . May not work if have more than one BT system active on your network...)
Interestingly, CHAT GPT may give some strange responses... not all are valid, or even factual... I played a 'game' with her, and she was so screwy, we had a system finally that would ONLY work properly in intense radiation environment on Jupiter, with communications through Voyager One... (well, not really, but equally as absurd)...
Threads: 15
Thanks for the inputs guys.
1) I was never in the area that allows you to select anything having to do with the web browser.
2) tried explicit http://192.168.1.111 No Luck.
Disconnected the controller form the network and ping 192.168.1.111 from a command window. As expected, "Reqeust timed out". So I do have the correct address for the Blitzortung controller.
Cutty and team:
Any thought on trying the remote server download and update of the firmware?
Threads: 3
Hi everyone,
This happened to me in November 2022 on System Blue version 9.5b1, and my station still responds with "192.168.1.235 refused to connect." as of today, using the http://192.168.1.235/index.cgi?action=login address. The station otherwise continues to operate 'normally', detecting and sending data to the servers.
The change magically happened overnight when no one was adjusting the station, and it was, and still is, powered via a 2KVA UPS, and no power outages nor fluctuations were logged prior to the event. When the UPS has kicked in, the station (and my PC) continue to operate normally durring the power event.
I did add voltage dividers to the two outdoor H-field loop antennas so I can attenuate them at my desk (10 turn pots), thus I do have operational control over sensitivity (just turn a knob and watch my station's real-time signals on Lightningmaps.org), but no chance of changing station gains, thresholds or any other settings. This antenna configuration is actually faster to adjust than using the keyboard and mouse, and has continuous adjustment steps over the full antenna signal, limited only by the potentiometer adjustment resolution. It is fun to use, and you don't need a damaged station to adopt this type of adjustable antenna configuration (no changes to the station are made).
Also, I changed my e-field antenna to use variable length pull-out segmented stainelss steeel antennas like portable radios have, so I get my exercise walking out to that antenna if I want to adjust its sensitivity by making it longer or shorter.
I am concerned that updating the firmware might make the station non-operable, and possibly unreplaceable given the manufacturing problems the BO Team has been facing, and those are far bigger problem than not having keyboard access, so I am living with the current situation.
Comments and suggestions are welcome.
Art Brown
San Ramon, CA, USA
Threads: 64
(2025-05-19, 13:39)W2PJ-WX Wrote: Thanks for the inputs guys.
Cutty and team:
Just won't grant access on network, or can't find on network, or request denied. ?
Doesn't matter... Do the factory reset.
I assume you had already had upgraded to latest firmware 11x?
If I understand, it was fine until you rebooted ?
It that is true, then Messin' with firmware should be a last resort... and a PITA
I find it hard to believe it got corrupted after successful upgrade, and previous functionality demonstrated.
Didn't you say somehow it had switched address from 110 - 111 by router?
That's not firmware.
Who knows what it is now? Router could send it anywhere I suppose.
I also understand that the web gui page won't open at all...
but ... Even if it's asking for 'login'credentials:
Let's get this simple. Before doing anything else, ....
Physically remove the power. Disconnect everything.
A minute or two, then
Connect GPS only.
Apply power.
Let it boot up and get 1PPS flashing.
That should clear everything 'temporary'
NOW
Do the factory reset to hard-coded settings. Not a reboot to saved settings. Since you can't access the tools GUI page, you MUST RESET with the manual method -- the button combos.
Let it reboot, GPS 1PPS flashes, etc.
Good
Reconnect EVERYTHING.
Apply power. Let Boot up & start.
GUI should work by accessing at http://192.168.1.235
about everything internal is now as it came off Egon's setup bench before leaving Germany, except for your locally loaded firmware. Everything else is square one.
I now should be able to connect it into my network just like a brand new system... if my network, browser/device etc is normal. I even had a case of a machine driving another network configuration that wouldn't connect because the NETWORK it was set to use did NOT include the Blitzortung system, OR and the url could NEVER be correct on that device! Reset the Windows Network on that machine. Voila! There she is!
Other than this, that's all I offer at least at the moment... .
Threads: 3
Another thing that comes to my mind is a problem resulting from the simultaneous use of static IP 192.168.1.253 while using a network of the same class, i.e. 192.168.1.x with a mask of /24. I suspect that for some reason cheaper routers allocate the MAC address of the device from the above static IP in the internal switch despite using DHCP, which causes the ping to return to the MAC/IP pair, in this case to IP 192.168.1.253. Try setting a static IP on your computer, i.e. 192.168.1.1, and connect the blitzordung to your PC back-to-back and check if you can connect to http://192.168.1.253 from a browser. If it works, you should probably reset the MAC/IP table in the router.
Jarek R,
Station: 2527
Threads: 15
First a reply to Station Roko:
Sorry to hear that you are apparently experiencing the dame problem as I am. Unfortunately, I do not think for a trying to adjust the gain on the antennas is a practical solution for me. I would rather try to fix the controller to be able to control the gains, thresholds and the various filtering options. I do have quite a bit of environmental noise, and the filters are reasonably effective. Noise levels vary over time and being to adjust from the controller is best for me but thank you for sharing your insights.
Cutty:
Thank you for your response as well.
To answer your questions, yes I have installed the latest firmware version (11.0b3). This was installed on March 31, 2025. It has functioned fine with no issue until yesterday.
Note also that I did not fix the GPS firmware for the rollover glitch that occurred last year. I did a workaround fix that I cannot remember the details of, that allowed the GPS and BT Servers to work together. I honestly do not remember what I did, but I did follow instructions for the work around provided when the problem occurred last year. When I saw the instructions for making a GPS FW upgrade, they appeared too complex for me, so I opted to stick with the workaround.
Repeating, all I was doing was adjusting gains and thresholds. It was after a reboot of the controller, that I initiated, that I was unable to connect to the controller from my Web Browser after the reboot completed.
The controller is still running after the re-boot, and I am still detecting and reporting to the servers (Station ID 2110. There is an electric cattle fence in my vicinity and that comes in loud and clear. that goes off 1/ second.
Unfortunately, the gain and thresholds and filter options I selected degraded performance substantially from my previous settings that were saved. So, I assume the controller rebooted back top those last saved settings. Again, I can still ping the controller and get a valid response.
Note that I am not a network or router expert at all. I can kind of just get by with the knowledge that I have. I understand some of the discussion on the links you provided, but some things I do not understand.
First, I would like to ask several alternate questions regarding approaches that may be easier than doing a full factory reset (at least for me and my limitted knowledge).
(1) One of the links you provided stated the following:
"Disable webserver"
Disables the webserver completely. It can only be enabled again by a factory reset or by a remote command.
I s it possible for you, or a developer or operator that is part of the Blitzortung team, to perform this function by remote command? Could this solve my problem with the Web interface?
(2) Another option might be to utilize the Automatic FW Update that was incorporated in Firmware Version 10.X and beyond. Again I am at vrsion 11.0b3.
THe Blitzortung literture states the following:
Firmware update¶
Automatic update¶
With firmware version 10 we introduced a new automatic update feature. In case of a new firmware release the controller itself can download the firmware file from our server. After that the downloaded firmware will be verified and can be written to the flash. Both, download and flashing can be triggered manually by you or by the server.
Is it possible for you, or a developer or operator that is part of the Blitzortung team, to perform an automatic FW version Update to either remote command?
It would seem that a remote upload of the controller FW if that is implemented would also update and fix whatever glitch there is in my ability to log into the controller with the web browser?
I thought I would ask if either of the above options are possible?
Now some questions on a factory reset, if that is the only way to proceed.
(3) Final Options "Factory reset to hard-coded settings"
Where can I find detailed instructions and maybe even a photo / illustration that shows me the PCB layout and button location(s) to perform the first series of steps... Is there a link with exactly how to do this procedure that you directed me to use See below.
"Since you can't access the tools GUI page, you MUST RESET with the manual method -- the button combos. Let it reboot, GPS 1PPS flashes, etc."
One of the links states that the procedure is to:
"Factory Reset by Button¶
Connect the power and hold the BOOT1 button while doing a short push on the Reset button. Still hold the BOOT1 button and wait at least 5 seconds. You might also hear a beep shortly after reset and then again after 4-5 seconds. After you release BOOT1 the system should do a reset and start again with factory settings.
I assume that Power is connected but the System Blue Controller On-Off switch is "off" when pressing the BOOT 1 Button while doing a short push on the Reset Button. Again, is their an illustration of which buttons on the PCB?
Of course, I will not get the 1 PPS flashes because of last years the roll over issue, so I guess ignore that step and move on?
As I recall the GPS FW update was somewhat complex. Sop that is why I just fixed it with the 9.4 firmware update (less elegant alternate, but simple fix).
When I update the controller FW via the Web Browser back to version 11.0b3, I should get the 1 PPS blue light sync to GPS.
When I put the controller back into my network, and reboot everything including my Router with the controller re-set to factor settings, wont my Router assign the IP address? Why do you say it ...
" GUI should work by accessing at http://192.168.1.235"
Wont I have to look at my Router Network Map to get the address the Router assigns, not likely that my LINKSYS Router would assign that IP? What am I missing here?
Thank you very much Cutty for your patience and help on this to get this problem resolved.
I would find it hard to believe it is a router problem or computer problem, hopefully just some kind of glitch in the controller that is reasonable easy to address via the various options above.
If Blitzortung via the Server could try a remote initiated FW update for me, that would be pretty cool! We could learn if it works to resolve a problem like this. If it did not work, I could always fall back to the manual reboot to factory settings you have suggested?
Cutty, final thoughts before proceeding with one of the options you recommend above?
R/
Pete - W2PJ
Threads: 64
Pete, replied to your PM... .
Threads: 15
With the help f Cutty (thank you!), my system Blue is restored, and I again have access to the GUI Controller User Interface from my computer. The factory reset was actually very simple. No updates to firmware required. Current version of installed Firmware is retained. Not sure why this happened but safe and easy to perform a factory reset per the instructions.
R/
Pete-W2PJ
