How to calibrate new station data to match the lightning map?
Hello everyone,
I just installed a Blitzortung station, and I find that the data sent to the map sometimes does not match the neighboring stations exactly. I would like to ask if there is a way to calibrate or optimize the settings (e.g., gain, threshold, antenna direction) to get more accurate lightning location results? Also, is there any recommended tool or documentation for beginners to calibrate stations?
Thanks, everyone, in advance!
Hi and welcome
If you tell us your station number, we can check on your status on the forum. You'll be able to read a lot more and find your answers since the question was asked many times in the past.
Bug Blitzortung Lightning Data does not show up in LightningMaps website ciavino.dellotto 1 4,574 2025-07-02, 06:42
Last Post: Eric.Wouters
  Problems displaying historical lightning data? Rain 4 20,200 2025-06-12, 15:13
Last Post: GeezerD
  Lightning block not showing map ramiroflores 1 9,347 2024-10-15, 18:55
Last Post: mwaters
  lightning data in a .txt or .csv (or similar) henry 3 9,571 2024-06-17, 05:38
Last Post: gerbold
  Lightning not showing on the map deesalsphotos 0 10,727 2021-12-26, 09:27
Last Post: deesalsphotos
