2023-11-01, 14:23
(This post was last modified: 2023-11-01, 14:40 by core.)
Hello! Other threads relating to this haven't been active for several months, so I figured I would start a new one. Was looking into setting up a detector to contribute data and get access to raw data, but it seems those are impossible to purchase at the moment, so instead I am looking into manufacturing my own.
I have located screenshots of schematics and board files at this link (
https://www.blitzortung.org/Compendium/H.../PCB_20_7/ which is linked publicly in the documentation), but I was unable to find any raw schematic files (to open with EDA software to generate gerbers). Are these available anywhere so I can generate files and order parts to manufacture a board myself?
Threads: 10
One person has made a small batch of them and will possible make some more in the future. There is a long list of people wanting to joing in.
Station 2828 -
LM or
BT
Yeah, I did see that earlier. Is my answer a no then? I could fairly easily source and manufacture a board myself but only if the correct files are provided - is there a way to get them or is manufacturing just done by this one person?
Threads: 63
(2023-11-01, 19:41)core Wrote: Yeah, I did see that earlier. Is my answer a no then? I could fairly easily source and manufacture a board myself but only if the correct files are provided - is there a way to get them or is manufacturing just done by this one person?
https://forum.blitzortung.org/showthread...5#pid25355
Threads: 3
(2023-11-02, 12:02)cutty Wrote: (2023-11-01, 19:41)core Wrote: Yeah, I did see that earlier. Is my answer a no then? I could fairly easily source and manufacture a board myself but only if the correct files are provided - is there a way to get them or is manufacturing just done by this one person?
Gerbers, drills and assembly are available. Eagle files too. What else do you need ?
Threads: 3
(2023-12-11, 04:34)ntguirre Wrote: Yes, I was aware of that earlier. So, is my response a no? If the right files are released, I could source and construct a board rather simply. Is it possible to obtain the correct files, or is manufacturing handled by this one individual alone?
We plan to assemble Blue system V22 ourself too.
Maybe to combine parts sourcing with you (share links for orders, etc...) ?
Does anyone know current status of PCB22 gerbers and where can be obtain them to try to assemble PCB22 unit ?
https://www.blitzortung.org/Compendium/Hardware/PCB_22/
