Firmware Download not possible
When I try to access the download site for system red firmware (http://tracker.blitzortung.org/firmware) I get an 404 error (even after login). Could anyone please check?
Thanks.
Stations: 868
(2025-06-08, 18:06)AHoh78 Wrote: When I try to access the download site for system red firmware (http://tracker.blitzortung.org/firmware) I get an 404 error (even after login). Could anyone please check?
Thanks.
Firmware and documentation have migrated since quite some time. Firmware can be found in this topic : https://forum.blitzortung.org/showthread...3#pid26813
Ok, thank you.
Could you pls fix the link at https://www.blitzortung.org/en/compendium.php?
Stations: 868
https://docs.lightningmaps.org/station-o.../firmware/
Regards Simon
https://www.conligwx.org
Stations: 1283, 3079
  Firmware 10 on System Red PCB 10.5 - firmware bug ??? mmlightning 1 13,652 2025-02-27, 08:37
