Blue H field Ferrite antenna in L or Delta shape?
(2016-11-02, 10:40)elythomaslumber Wrote:
(2016-11-02, 10:23)nellyt Wrote: Assembly instructions linked from http://en.blitzortung.org/cover_your_area.php
say to put the 2 (or maybe 3) ferrites at 90 degrees.
The picture on the same page http://en.blitzortung.org/cover_your_area.php
shows the ferrites in a 120 degree delta
What should I do?
Have I missed some documentation/description somewhere ?
thanks
Have a look into the Assembly instructions chapter 4.2: Antenna
Scroll down and you will find a picture with 2 horizontal ferrite antennas 90° and one vertical in 90° to them  Smile
Thanks, but I realise you can put two horizontally at 90°, and optionally put a 3rd at  90° to them....
but....
why the picture of three in a delta.? There is no description of deltas in the instructions ?
Which one should I be building
Why the picture of the delta if they are all meant to be at  90°
Stations: 1685
RE: Blue H field Ferrite antenna in L or Delta shape? - by nellyt - 2016-11-02, 10:47
  Making a copper tubing H-field antenna Geewizard 3 2,206 2025-06-02, 18:02
  Blue e-field antenna question llowrey 2 14,047 2021-07-06, 14:34
Last Post: llowrey
  My E-field antenna setup TomVal 3 18,804 2020-11-05, 15:48
  blue ferrite / loop antenna connection? MTO-Mareuil 1 12,015 2020-10-20, 11:43
  GPS antenna SYSTEM BLUE ! IK1TTD 9 59,247 2020-06-03, 12:16
Last Post: GJ7DNI
