Making a copper tubing H-field antenna
I've seen several H-field orthagonal loop antennas using copper tubing on the forum.
How is the loop wire put inside the copper tubing?  What gauge wire?  How many turns?
Details would be appreciated!
Stations: 3173
(2025-06-02, 14:29)Geewizard Wrote: I've seen several H-field orthagonal loop antennas using copper tubing on the forum.
https://forum.blitzortung.org/showthread.php?tid=1708
Have fun...
Seriously, tried 'bout all types H field, over the years... below are orignal draft infos, and no doubt need 'fixing', but...
have two 'innovations' I favor, with the my 'wheelie' being number one...
https://frankfortweather.us/blitzblitz/S...Vshort.pdf
Yeah, the 'specs' and stuff are rough figures, and maybe a little screwy, and poor examples, but can't beat the performance.
and
The 'CSS Thingie' ferrite:  beats heck out of any of my other ferrite builds, second only to the Wheelie for response and resonance...
(Huge PDF file)  https://frankfortweather.us/blitzblitz/C...hingie.pdf
Whatever theories and measurements, both prove themselves in operation.
...and, if you stick a thingie inside a "Pesky Shield", might just eliminate a strange interferer or two, plus a bit of signal enhancement.
(Huge PDF file)  https://frankfortweather.us/blitzblitz/C...Shield.pdf
Aw Cutty, that's just perfect! I'll build a Wheelie and see how it goes.
Thanks.
Stations: 3173
(2025-06-02, 16:49)Geewizard Wrote: Aw Cutty, that's just perfect!  I'll build a Wheelie and see how it goes.
Thanks.
dupreezd
https://forum.blitzortung.org/member.php...e&uid=3715
came up with some SUPER forms to wind those wheelies on... much better than my quickie proof of concept styrofoams...
  Blue e-field antenna question llowrey 2 20,142 2021-07-06, 14:34
Last Post: llowrey
  My E-field antenna setup TomVal 3 25,103 2020-11-05, 15:48
  Can E-field antenna be casted in resin? OH4GRM 3 24,789 2020-06-01, 13:19
Last Post: dupreezd
  E field antenna height DrRobin 10 69,823 2017-11-04, 16:31
Last Post: Benedict.Smith
  E-Field Antenna and 60 Hz power lines waysta 4 37,682 2017-06-09, 23:11
Last Post: radiofarol
