Blue H field Ferrite antenna in L or Delta shape?
(2016-11-02, 12:19)Cutty Wrote: An important note here:  BLUE SYSTEM - The 3rd channel of H field amplifier (on the controller) and the single E field amplifier share the same ADC.... (RED system operators with E field should be familiar with this confusing operation)... which means basically the 'lowest threshold' on either channel (H3 or E1) will be the threshold of the other ,,, you can follow our struggle with this a couple of years ago when E was added to RED... we finally figured it out... at this board: http://www.wxforum.net/index.php?topic=22710.0
If I build a loop should I build the conventional loop antenna with 90° lobes and add a horizontal loop around the outside or inside of the conventional loop antenna? Or would the horizontal loop be a separate antenna?
The horizontal loop would be connected to channel 3.
Michael Lloyd  NE5U
Weimar, TX USA
Stations: 1745
RE: Blue H field Ferrite antenna in L or Delta shape? - by Mike6158 - 2017-03-29, 23:36
  Making a copper tubing H-field antenna Geewizard 3 2,564 2025-06-02, 18:02
  Blue e-field antenna question llowrey 2 14,354 2021-07-06, 14:34
Last Post: llowrey
  My E-field antenna setup TomVal 3 19,143 2020-11-05, 15:48
  blue ferrite / loop antenna connection? MTO-Mareuil 1 12,311 2020-10-20, 11:43
  GPS antenna SYSTEM BLUE ! IK1TTD 9 59,679 2020-06-03, 12:16
Last Post: GJ7DNI
