System blue antena setup site.
(2019-05-09, 02:04)cutty Wrote:
Axrually, the "horizontal" loop on the ceiling will function quite well for Horizontally polarized impulses..
it's settings would be similar to the loops on HA and HB... unless you have a lot of horizontally polarized H noise, and it may NOT detect as many strokes as ethe others..depending of type of impulse etc... Yes, the system WILL process them, if enough stations detect them on C.. it won't display them as a special type, however... just a stroke.
You need to connect the horizontally polarized loop, whetehr Ferrite, wire, whatever, to H channel C input...
I've been running C as Horizontally polarized for some time now.
ou can then add Vertically Polarized (normal) to H A, and H B...lIf theyre Ferrites, the sticks lie horizontal, if wire, loops, mount vertical.
for horizontally polarized impulses, ferrite mounts Vertical, and wire mounts horizontal, always on channel H C
Make sure your station is configured correctly on your Operator's page'... Have you registered your station?  If so, what's the number and location???
Thank you. This is the very first time that I  have ever heard this. Is this documented anywhere else besides this post?
RE: System blue antena setup site. - by cutty - 2019-05-09, 02:04
RE: System blue antena setup site. - by mwaters - 2019-05-09, 02:41
RE: System blue antena setup site. - by cutty - 2019-05-09, 03:01
  Antenna setup. josecmorales 1 5,921 2021-07-19, 16:23
  My E-field antenna setup TomVal 3 12,148 2020-11-05, 15:48
  Account Setup Mike 27 96,670 2018-12-07, 21:21
Last Post: Mike
  H-Field Ferrite Rod Antena Parameters dieron 2 15,227 2017-02-28, 19:10
Last Post: RichoAnd
