My E-field antenna setup
            Hi, got my E-field antenna setup yesterday.
I clear coted the circuit board with a couple of clear varnish for extra protection against the elements. I protected the connectors with masking tape during the spaying.
The antenna is attached to a antenna pole on a steep high ground close my house.
I plan to get some stuff for sealing the boards before sending them outdoors I think its called an Acrylic Conformal Coating.
Station 2828 - LM or BT
Stations: 2828
I like the setup.
Station: 2521
I'm not a big fan of metal poles or clamps for the efield assy.... especially if a metal mount is grounded, and/or there is electrical noise in area. Remember, it functions best on capacitance between probe and earth. Mine are on fiberglass, simply taped to the mast. https://forum.blitzortung.org/showthread.php?tid=2749
Suggest use "Stuf" inside the coax connector.
  Making a copper tubing H-field antenna Geewizard 3 2,510 2025-06-02, 18:02
  Antenna setup. josecmorales 1 11,292 2021-07-19, 16:23
  Blue e-field antenna question llowrey 2 14,276 2021-07-06, 14:34
Last Post: llowrey
  Can E-field antenna be casted in resin? OH4GRM 3 18,861 2020-06-01, 13:19
Last Post: dupreezd
  Account Setup Mike 27 127,410 2018-12-07, 21:21
Last Post: Mike
