Max Cable Length
What would be the max cable length that could be used between a ferrite antenna and the reciever? Would like to mount antenna as remote as possible to alleviate noise.
Thank You
From the manual :- "The H-field pre-amplifier is connected with a shielded twisted pair cable (FTP, STP, S/STP, or
S/FTP) to the main board. This cable should not be placed next to the network cable. Please
keep a distance of at least 10 cm. The cable may have a length of up to 30 meters."
Hope this helps.
  e-field antenna length question.. Aythya 5 48,993 2015-08-25, 19:40
Last Post: Aythya
  controller cable Jim Mandaville 8 66,080 2015-02-05, 06:37
Last Post: Gerard.Parat
