Blitzortung doesn’t work
I have problems getting blitzortung to work. it always gives me “unavailable”, even when there’s a thunderstorm in the area. i can’t find out what is wrong.
here’s the code for the card:
Code:
type: entities
entities:
  - entity: sensor.blitzortung_lightning_azimuth
    secondary_info: last-updated
  - entity: sensor.blitzortung_lightning_distance
  - entity: sensor.blitzortung_lightning_counter
state_color: true
hi Colebonelli,
Could you please share a screenshot of the detector webpage?
I'm curious what status it shows there.
Stations: 3050
(2024-10-15, 07:50)colebonelli Wrote: Hello,
I have problems getting blitzortung to work. it always gives me “unavailable”, even when there’s a thunderstorm doodle jump in the area. i can’t find out what is wrong.
Code:
type: entities
entities:
state_color: true
It seems like the issue could be related to either the Blitzortung integration setup or the sensor data not being received properly.
  New system - not certain if it work Bobby_Two_Dogs 7 4,897 2024-04-26, 16:15
  ELI5: How do lightning tracker websites work? Johnlarry 2 15,925 2020-06-09, 10:10
Last Post: scilover
  Some questions for begin of station work hashemiyan 1 12,594 2016-05-16, 13:59
Last Post: DelandeC
