E-Field Antenna and 60 Hz power lines
System BLUE have a HP filter that reject perfectly the 50/60Hz electromagnétic field. . The problem is the harmónics generated by arcing in the power system trought our components leaks. I have 3 power lines (two of 30Kv and one 15Kv) about 50m away from my house and with hP filter on, I have no problems! The big problems are the omnipresent switching power supply, and the switching celular chargers! Today I installed the digital lowpass filters in all channels and it seems working fine. I tuned the filter in 40Khz and much of the noise go away!
RE: E-Field Antenna and 60 Hz power lines - by radiofarol - 2017-06-09, 23:11
  Making a copper tubing H-field antenna Geewizard 3 19,776 2025-06-02, 18:02
  Blue e-field antenna question llowrey 2 21,680 2021-07-06, 14:34
Last Post: llowrey
  My E-field antenna setup TomVal 3 26,926 2020-11-05, 15:48
  Can E-field antenna be casted in resin? OH4GRM 3 26,496 2020-06-01, 13:19
Last Post: dupreezd
  E field antenna height DrRobin 10 74,062 2017-11-04, 16:31
Last Post: Benedict.Smith
